Monitoring web usage for IP address remotely, Help?
Hello,Im looking for a way to monitor employees web surfing usage and how much bandwidth is being used for each IP Address.
We using a zxyel Router and our bandwidth is being chewed up and suspect its being used on web surfing activity, the email usage is high as well.
Is there a way to monitor who is using what and from the router?
Desperate Need of Help!!
Many Thanx
Cat
2 answers Last reply
More about monitoring usage address remotely help
  1. And hopefully a free software
  2. The router will have logs you can turn on. Do you have a PC usage policy setup at work? If not, I suggest you come up with one and make sure the employess read and sign it before you start monitoring them.
    If you need something more robust you can setup a proxy server that filters and monitors all network traffic.
IP Address Bandwidth Monitors Routers Apps
