Hello.
I have a dell dimension 3100c running win xp home.
My problem is every time I boot it up it gets half way though booting windows then says something to do with defragmentation for 1/2 seconds then carry's on fine and it all works fine. (I will add a photo )
http://s269.photobucket.com/albums [...] GP3206.jpg
I was wondering if there is a way to stop that?
any help would be good thanks frog.
Sponsored Links
FYI, your link doesn't work without a login.
Have you tried running a defrag to see if that'll stop the message?
------------------------------ CM HAF 932 - 300GB Velociraptor
GIGABYTE GA-EP45T-DS3R
E8500 - Sapphire 1Gb 4850
4G DDR3 OCZ Reaper 1333
Reply to aford10
Thanks for your reply I have got it fixed and sold it!
thanks any way frog
Reply to frog46
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Booting problems
There are 1258 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
