Tom's Hardware > Forum > Wireless Networking > Setup, Configuration & Security > Wired network, or wireless... I'm not sure which I am!
Forum Wireless Networking : Setup, Configuration & Security - Wired network, or wireless... I'm not sure which I am!
I scanned the FAQ section and did a few searches, but I think my question is a bit complicated to search for.
I just set up a new wireless router that I have connected to my computer via a wired connection. By this, I mean I have my modem connected to my router and my router connected to my computer. The only reason I got a router was for my Wii & DS and for eventually to use Skype with a specialized phone.
My question is, do I need to secure my router so that no one can access my connection and whatnot, or is my system and connection safe given my wired connection? I would think that if my Wii can pick up a wirelss signal anyone nearby could as well. If there are security settings I need to implement, what (in general) would I need to do to shut out unwanted users?
Does what I've asked make sense? This is my first go at using a router, so please forgive my ignorance. Thanks.
Message edited by magicant on 05-10-2008 at 02:26:41 AM
Sponsored Links
yes you need to secure it. Under wireless security choose WPA or WPA2. Then encryption type does not really matter. Then, enter a strong passkey. When you try to connect on your wii and ds you will have to input that passkey.
Reply to thehelo
There are 1060 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
