help in sounds start up
Forum Windows XP : Windows XP General Discussion - help in sounds start up
Archived from groups: microsoft.public.windowsxp.basics (More info?)
hello I just wondering if somebody can help me in this concern i lost some
sounds in my start up windows log on xp play a sound when start ,also when
you browse in the internet explorer like a click,and when you download
something and the task is complete ....I was seraching all my pc for this
...my volume is ok ..my messenger is ok means play sounds notifications etc
...but whats is going on in my other sounds.....?..please help
Sponsored Links
In news:88DEAFB7-4D33-42F5-910D-18D735B0C947@microsoft.com,
luishugo <luishugo@discussions.microsoft.com> had this to say:
My reply is at the bottom of your sent message:
> some sounds in my start up windows log on xp play a sound when start
> ,also when you browse in the internet explorer like a click,and when
> you download something and the task is complete ....I was seraching
> all my pc for this ..my volume is ok ..my messenger is ok means play
> sounds notifications etc ..but whats is going on in my other
Start
Settings
Control Panel
Classic View
Sounds and Audio Devices applet
Sounds tab
Drop down menu set to Windows Default
Click OK
Galen
"And that recommendation, with the exaggerated estimate of my ability
with which he prefaced it, was, if you will believe me, Watson, the
very first thing which ever made me feel that a profession might be
made out of what had up to that time been the merest hobby."
Sherlock Holmes
Reply to galen
hello i still have the problem
> Start
> Settings
> Control Panel
> Classic View
> Sounds tab
> Click OK
> Galen
> Sherlock Holmes
Reply to Anonymous
In news:35666859-6A8D-4138-B614-6E5BCECF0FA9@microsoft.com,
Well, did you make the changes and set it back to the Windows default? Did
the option stick? After you set it back did you open it again (the sounds
applet from the control panel) and was it set on default? Was it already set
on default?
Galen
Sherlock Holmes
Reply to galen
Hello Galen thanks for all this help..let me tell you something I think I got
thsi problem since I installed a new media keyboard " Multimedia keyboard" or
maybe I am wrong..well anyway I followed your instrucctions but when I
selected "Windows default sheme" ..I click "Ok" and when I come back to
check my selection inthis sounds folder I noticed to the selection I did
didn"t stick and have a "default" select in that window....????.......what I
can do...? my messenger,have a sounds but my start up log on windows sound
and my web search sounds dissapeared...thanks...
> on default?
> Galen
> Sherlock Holmes
Reply to Anonymous
In news:F2E6C164-7E1D-4A3D-B906-725CAFC296DC@microsoft.com,
> think I got thsi problem since I installed a new media keyboard "
> Multimedia keyboard" or maybe I am wrong..well anyway I followed your
> instrucctions but when I selected "Windows default sheme" ..I click
> "Ok" and when I come back to check my selection inthis sounds folder
> I noticed to the selection I did didn"t stick and have a "default"
> select in that window....????.......what I can do...? my
> messenger,have a sounds but my start up log on windows sound and my
I would try adding on manually - like the startup wav file and rebooting to
see if it sticks. If it does you may have to go ahead and make your own
custom sound settings by putting the correct sounds (or any you happen to
feel interested in) into the drop down menu box for each of the events in
question. However, a restore to a date/time prior to this change might be
effective as well.
Galen
Sherlock Holmes
Reply to galen
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > help in sounds start up
There are 1067 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
