The motherboard went south. Like everone else I have photos and info in the harddrive I want to access. I removed the hd from my brothers working computer and installed mine. It booted fine, I got some of the stuff onto cd's and then a message came up. Something about having three days to recertify or validate the system. I reassambled my borthers computer as it was and all was fine. I built a new system from the ground up and now when I boot the old drive I get the following message and it just keeps going a rebooting cycle. Technical Info Stop: 0X0000007E (0XC0000005, 0XF748E0BF, 0XF78DA208, 0XF78D9F08) Pci.sys - address F748EoBF base at F7487000, Datestamp 367d855c. What up with this? Is this a program Microsft built into th XP Home Editon so you can only install it once? I ahave a new HD with XP Pro x64 and the system works fine. Whats up with the drive?
Please Help
JSS
Sponsored Links
Did the drive have XP SP2 on it? You may need to slipstream an install disc with SP2 and reinstall.
------------------------------ CM HAF 932 - 300GB Velociraptor
GIGABYTE GA-EP45T-DS3R
E8500 - Sapphire 1Gb 4850
4G DDR3 OCZ Reaper 1333
Reply to aford10
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Booting problem
There are 1224 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
