So here's the deal...
I have an older Socket 939 eVGA NF41 mainboard to go along with a 3700+ San Diego. I decided I'd dabble a little in overclocking with my existing processor before upgrading to an Opty 170. I took my first little step this morning and had quite a big snag...
I adjusted the "CPU Clock at Next Book is" setting from the default 200mhz to 210mhz... That should have boosted my overall CPU speed from 2.2ghz to 2.31ghz in a single step. If it were unstable, I still would have been able to boot up the computer.
However, as soon as I saved the BIOS settings and restarted the system failed to boot. It gave me a Post Code 26, and after a brief panic I reset the CMOS successfully. The only setting I adjusted was the CPU Clock speed, which I assumed would be harmless at a 10 mhz jump... Can someone perhaps tell me what I'm doing wrong here? Why would the entire board fail like that? Perhaps my memory timings were too high and I overloaded the CPU's memory controller? I can't imagine I'd have to crank up the mainboard chipset voltage with such a small tweak, so I'm thinking it's memory. I had the timings set at 2-3-2-5 1T, which is pretty fast. I at least should have set it to 2T.
Anyway, I still have the original BIOS and have not flashed it at all. I suppose I should, as the original BIOS (purchased in September of 2005) isn't very OC friendly. Any advice would be greatly appreciated, fellas.
