Hey i have a built in tv tuner and it was working for so long. Now when it is ho
Hey i have a built in tv tuner and it was working for so long. Now when it is hooked up through media center the signal is very blurry. I split the cable from dwnstairs with a dynex splittler (bought at best buy) so I know it is the computer. It is a hp m9340f with a built in tv tuner. Please someone help me fix this
2 answers Last reply
More about built tuner working long
  1. Have you tried to unsplit the cable and see if it is better?
    Just because you have a Dynex doesnt mean that doesnt have a short somewhere.
    Did create the second cable youself?
  2. If the splitter isn't rated for the bandwidth that its using, it can degrade over time.
    This happened w/ me and a HDTV, but it can also occur with a standard definition signal as well. I would try using a heavier duty splitter. Mine is in the 1000 Mhz range.
Drivers TV Tuner Windows Vista
