QTECH 2.2ghz, 80Mb
XP service pack one (I think)
I'm genuinely stuck with this PC I have been given.
OK story,
A neighbour gave me a PC. He said it was broken so he went off and purchased another. When I cleaned out the USB female plug it appeared to clear the short and the PC turned on.
Great, quick check of the CPU revealed a 2.2ghz Pentium 4 and 80 Gig hard drive. All was working and seem fine so I was smiling! So I started to set this one up for the kids and this is where I hit problems.
I put in some cards in and installed a copy of Battlefield1942 It was then I noticed that Battlefield 1942 was loading really slowly, If I was to guess I would say the access time of the hard disk was down, it seemed generally slow in anything related to hard disk access time.
In the end I decided the best thing to do was reformat, new system and build up the drivers from base up so I knew the new PC inside out and it was cleaned.
The damn thing will not install XP now. I have used the OEM(QTECH recovery v6) disk that came with it, it will take about 4 hours and lock up! So I figured I would try another copy of XP instead of the CD that came with it. This crashed after a few hours also, blue screen this time.
Now I don't have any ideas, I have tried three XP copies, none work!
I have tried searching for any company called QTECH that make computers! - no joy!
anyone
help!
please!
grovel!
OK story,
anyone
help!
please!
grovel!
