More on JIT Debugger problem - I still need help
Archived from groups: microsoft.public.windowsxp.general,microsoft.public.windowsxp.basics (More info?)
From what I read on the web, it seems highly likely that the problem
is due to the presence of DELL stuff on my friend's machine (DELL
Support, DELL Solution Center, etc). In fact, I can eliminate some
(not all) errors due to this JIT Debugger thingee by removing
'support.exe' from the task window,
Her machine came two years ago with XP HOME SP1 (OEM!) which I
upgraded to SP2 yesterday. I also downloaded/installed all of MS's
security updates.
I really want to remove all the DELL stuff from her desktop, etc, but
it won't let me do it. I have to wonder if her version of XP would
run without the DELL stuff anyhow.
I have looked to see where in the boot process, the DELL stuff is
picked up and started, but cannot find anything in the ini files, nor
in start folder. There are many references in the registry, but I am
afraid to remove them - and there are many.
Can anyone help me here?
Thanks
4 answers Last reply
More about more debugger problem help
  1. Archived from groups: microsoft.public.windowsxp.general,microsoft.public.windowsxp.basics (More info?)
    > security updates.
    > Thanks
    For goodness' sake, why wouldn't you just go to the Add/Remove Programs
    applet to remove Dell's preinstalled software? If you go there, you'll
    see that you can uninstall the Dell Media Experience, the Dell Solution
    Center, and Dell Support - all of which you should do. I'm sure you are
    a good friend, but perhaps having your friend take the machine to a
    computer professional might be a better idea at this point.
    Malke
    Elephant Boy Computers
    www.elephantboycomputers.com
    "Don't Panic!"
    MS-MVP Windows - Shell/User
  2. Archived from groups: microsoft.public.windowsxp.general (More info?)
    On Wed, 08 Jun 2005 08:17:00 -0700, Malke <invalid@not-real.com>
    >Malke
    Owwcchh!
    Cya
  3. Archived from groups: microsoft.public.windowsxp.general (More info?)
    >Malke
    Before I 'Cya', you should know that I did try removing DELL stuff in
    Add/Remove Programs. It seemed the obvious thing to do.
    It will not let me do it - even tried it in safe mode.
    Cya2
  4. Archived from groups: microsoft.public.windowsxp.general (More info?)
    >>Programs applet to remove Dell's preinstalled software? If you go
    >>there, you'll see that you can uninstall the Dell Media Experience,
    >>the Dell Solution Center, and Dell Support - all of which you should
    >>do. I'm sure you are a good friend, but perhaps having your friend
    >>take the machine to a computer professional might be a better idea at
    >>this point.
    >>Malke
    > Cya2
    Then there is more wrong on the box than is apparent from your posts.
    All those programs uninstall perfectly under normal circumstances; it
    is one of the first things I do when I'm optimizing a Dell box for
    clients.
    I'm not trying to hurt your feelings when I suggest having a
    professional look at it; I'm just being practical.
    Malke
    "Don't Panic!"
Microsoft Debugger Dell Windows XP
