I've been having issues with my Wireless Internet lately.
Just so I don't get retarded responses, I'm hardwired right now(router is bypassed).
Two days ago, one of my computers was having issues with the internet, so I reset the modem/router.
When it came back up, the internet had 'little or no connectivity' on both of them.
I called Comcast(My ISP), because even hardwired my internet didn't work.
They looked around at my settings, and somehow my TCP/IP settings got changed off of automatic.
Then hardwiring worked.
But, no matter what I tried... my router was lifeless.
I couldn't connect to 192.168.1.1
My wireless connection still had 'little or no connectivity'.
So, I called up my brother, and we talked about it, and I realized I could factory reset my router.
So I reset it(probably 2 hours ago) and I was finally able to connect to 192.168.1.1
My Wireless Connection lost the 'little or no connectivity' and now its fine.
But... Obviously, when I factory reset, my settings changed... So I put everything back in(to my knowledge I didn't miss anything)
And.... it still doesn't work.
Here's my ipconfig\all
I noticed, there is no Primary DNS Suffix, but I had a hard time searching for that on google, and have no idea how I would fix it(if it is a problem).
Thanks ahead of time for all of you that read this.
If you fix my wireless, I will love you for all eternity(No joke... I got hookups).
Power off your cable modem and router, connect an ethernet cable from the modem to the Internet port on the modem, power on the modem and wait until it's online (Ready or Cable light solid). Power on your router and try the Internet.
I've had this wireless connection for probably 2 years and havn't been able to get it to connect wired for 6 months(with any ethernet cable or any of the 4 ports on the back)
I know it's very old... but I don't see the need to jump and buy one when it has served no issues since 3 days ago.
I've had this for quite a while(before I used it at my house).
That has nothing to do with your problem. You need to look at the Status page of your router and see if you're getting a Comcast assigned IP address. You might need to clone your PC's MAC address.
Read what I wrote again. 192.168.1.100 is the IP address assigned to your computer by your router. Open a browser and type 192.168.1.1 in the Address Bar. Use admin for the Username and Password. Click on the Status page and post the Internet IP Address.
