Tom's Hardware > Forum > General Networking > General Gateways, Routers and Firewalls > setting up wired/wireless routers on same subnet?
Forum General Networking : General Gateways, Routers and Firewalls - setting up wired/wireless routers on same subnet?
Ive got a Zywall 5 that takes care of all my wired network (running through a dell gigaswitch)
Then I have a Dlink DIR-655 taking care of my wireless network.
At the moment they are setup on two seperate subnets (192.168.0.x and 192.168.1.x)
This gives me a few problems since certain for different reasons cant communicate across networks.
So Id like to basically have the dlink act as an AP (ie: not router) on the Zywall network, so all ip adresses on the network will be on the same subnet.
But as far as I can see the dir-655 does not have any setup options, to make it act as a dummy ap?
Id love to have some suggestions as to how to approach this.
kind regards
Sponsored Links
Disable DHCP on the D-Link and connect the network cable from the Zywall to a LAN port on the D-Link.
Grumpy
Reply to Grumpy9117
tried that.. didnt work :/
Reply to kurgandk
Change the IP address to be in the 192.168.0.x range. Are you sure you used a LAN port on the D-Link? Do you get an IP address when connected to the D-Link?
Grumpy
Reply to Grumpy9117
yes. but it seems the dlink insists on wanting to act as a router..?
Reply to kurgandk
You must have missed something.
Grumpy
Reply to Grumpy9117
There are 1103 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
  • 01:00 xpax won the Freshman badge
  • 01:00 Mizoguchi won the Freshman badge
