I am still a noob but I did take a hardware class and several other computer related classes first. I bought a barebones setup from tiger that consisted of a case, Asus P5NSLI NVIDIA Socket 775 ATX Motherboard,
Intel Pentium D 940 3.20GHz OEM Processor, NEC Super Multi (AD-7170A) 18x DVD±RW DL OEM DVD Burner w/Software, Ultra X-Finity 500-Watt SATA/SLi Ready Power Supply. The rest I bought from zipzoom and newegg: Seagate Barracuda 7200.10 ST3250620AS 250GB Serial ATA (3.0Gb/s) 7200RPM Hard Drive w/16MB Buffer, BFG geforce 7950 gt oc (just one), Kingston 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300) Dual Channel Kit Desktop Memory - Retail, Ultra / Fire / Socket 775 / P4 3.8Ghz / Copper Core / CPU Fan. Sorry about the mess had to copy paste. Basically it started first try, then everything worked except maybe it froze once or twice. When I started to try playing games(cod2, and others) it would almost instantly bsod, black screen, freeze ect. I tried several grapics drivers old and new with no results. I updated the bios and chipset and then It would last 30 mins or so before displaying input not supported on my lcd. I tried diff monitors. I rma'd the graphics and got another. Same issues only some freezing as well. As far as I could tell the power supply had enough on the 12v rails? The only thing I could find wrong and I am not sure when it started, but the irq 0 and 8 had yellow flags along with one device on the pci bus. I watched the temps which never got high at all except the graphics card which never broke 70C. I suspected the northbridge or something similiar. I sent back the mobo to tiger and told them I wanted something different. So I am trying to find a good mobo to go along with my specs. I was building a cheap gaming computer for wow and cod2 ect. Nothing special. Now I have read alot of bad reviews on almost every asus board im looking at. So, what should I do. Should I just suck it up and buy another asus which I will have to set all the timing and voltages and tweak until my eyes pop out? Any suggestions. I am somewhat new but I think I could set the timing manually and voltages without too much trouble. You think the p5nsli was just faulty or didnt like my ram(Pretty sure it was on the qualified list)? Everything else worked fine(movies, surfing) just not gaming. I was wondering if I should have messed with the timings and such but like I said it was working well except for games so i figured timings and voltage wouldnt make a diff.
