Problem of USB Cables
Hi all,
I want to know the difference between USB 1.1 and USB 2.0 Cables?
Or they are no difference ?
thx ur ans :D
2 answers Last reply
More about problem cables
  1. USB 1.1 cable not guaranteed to work at USB 2.0 speed, so only buy USB 2.0! Try it and see, may work if good quality USB 1.1 USB 2.0 is backwards compatible.
    Mike.
  2. mike99 is exactly right. In my experience, 1.1 cables can be finicky with 2.0 peripherals (especially if the cable came from the dollar store). If your PC keeps making the USB connect and disconnect sound notifications over and over for no reason, spring for the 2.0 cable
USB Cable Components
