Problem with Control Panel Add/Remove option
Archived from groups: microsoft.public.windowsxp.basics (More info?)
Half way down the list of programs to remove it starts a black vertical
line that seems to last forever, then is changes to 2 lines, the 3. I
can scroll for a while, and then the rest of my programs show. When I
click on the black lines it highlights blue, but it does not give me an
option to do anything with it. What can it be and how can I fix it?
Thanks!
19 answers Last reply
More about problem control panel remove option
  1. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    There is an invalid entry in the Registry at
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall,
    where the data for this list is stored. The invalid entry usually is
    the next one after the one that is displayed before the list is
    interrupted.
    (tm)
    ICQ: 192649233
  2. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    Still no luck. I uninstalled the program above and below the lines and
    then made sure the registry keys were deleted.
  3. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    I have exported it. I opened it with Word and it is 45 pages long, do
    you want me copy and past it here?
  4. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    I figured that if I un-installed the program it would take it way from
    the registry. After un-installing them I deleted the remaining folders
    in the register, then I ran a registry cleaner. Another website
    suggested a negative value for the icon, I check all
    of them within the uninstall folder. All the ones that had it icons
    listed did not have values at all, just a file name. There were two or
    three that listed nothing under the icon section. I know a little
    about editing the registry, but I would not do anything
    without someone telling me to do so, and making a backup.
  5. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    Why would you uninstall anything.
    Export the registry key and post here.
    Type regedit in Start Run
    http://webdiary.smh.com.au/archives/_comment/001075.html
    <navygin21@yahoo.com> wrote in message news:1118426156.469336.12440@f14g2000cwb.googlegroups.com...
  6. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    The symptoms are a little bit different. For -1 there is a white space that is selectable, as the white space is the space Add/Remove thinks the icon is (it thinks it's really big).
    "Thorsten Matzner" <tmatzner@gmx.net> wrote in message news:Oso$RaZbFHA.2444@TK2MSFTNGP15.phx.gbl...
    > interrupted.
    > (tm)
    > ICQ: 192649233
  7. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    There is a problem where -1 is used for an icon index. Positive and zero numbers mean the nth icon in a file (0 being the first icon, 1 is the second, ..., n is the nth + 1), Negative numbers, except for -1, is the resource ID of the icon (the number the programmer gave it when s/he refers to it - if they want to display an icon with a resource ID of 1025 they specify -1025). -1 is the total number of icons in the file. So instead of getting a valid handle to an icon it gets a number which is an invalid icon (or a random icon if you fluke it).
    The icon parameter in Add/Remove is optional as Windows will guess the icon if you omit it, but may guess wrong. The only entries one needs is Uninstall String and Display String - Windows guesses all other values.
    However your symptoms are a bit different. If -1 is used it's just a big blank icon that forces the text that is normally to the right of the icon to wrap below the space reserved for it. But it is WHITE and selectable.
    email the file to david at mvps.org
    <navygin21@yahoo.com> wrote in message news:1118443037.505161.101070@o13g2000cwo.googlegroups.com...
  8. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    I also need this key as well
    HKEY_CLASSES_ROOT\Installer\Products
    And also some idea of what is above/below the black space. But I'm going to sleep now.
    "David Candy" <.> wrote in message news:#Q9mPEhbFHA.3492@TK2MSFTNGP14.phx.gbl...
  9. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    HKEY_CURRENT_USER\Software\Microsoft\Installer\Products
    and this one.
    "David Candy" <.> wrote in message news:ObJGxdhbFHA.2984@TK2MSFTNGP15.phx.gbl...
  10. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    Still no luck. Since everything looks fine I guess I should do a fresh
    install of Windows. Thanks for looking into it for me.
  11. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    Ok. I made my registry exactly the same as yours. I don't see the problem. Everything is perfect.
    This has fixed it for one person last week (from Ramesh).
    Delete
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Management\ARPCache
    (it will be rebuilt from the other keys we've discussed here and via mail next time you open Add/Remove).
    "David Candy" <.> wrote in message news:eR$9HlhbFHA.3492@TK2MSFTNGP14.phx.gbl...
    and this one.
  12. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    Wouldn't it be easier to ignore it.
    <navygin21@yahoo.com> wrote in message news:1118511542.373238.276580@g47g2000cwa.googlegroups.com...
  13. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    If this is an icon problem, I remember something from earlier versions of
    windows there was a file you could delete and it would be rebuilt. Seems
    like it was called ShellIconCache or something like that. Is that type of
    solution no longer workable in WinXP?
    Clark
    news:epAfV1qbFHA.2420@TK2MSFTNGP12.phx.gbl...
  14. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    C:\Documents and Settings\David Candy\Local Settings\Application Data\IconCache.db
    Is XP's equiv.
    "Clark" <who@whoknows.com> wrote in message news:ljGqe.2574$751.2453@newssvr30.news.prodigy.com...
    > Clark
  15. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    I beleive you mean the shell file that would appear on the desktop.
    That is not the same.
    PCDaddyPosted from http://www.pcreview.co.uk/ newsgroup access
  16. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    David: I could ignore, but not to sound too anal, it is something that
    would always bother me. I like my computer to be squared away,
    everything to be the way it is supposed to be. I do appreciate you
    looking into it for me. I tried to call my tech support, but
    apparently it does not cover software.
    Clark: That didnt help either, but it never rebuilt itself.
  17. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    Instead of reinstalling Windows, I started to go through and delete one
    program at a time and I finally figured it out. It was a program
    called ringtone ripper. It was not showing up the add/remove program
    list but it was listed on the registry to be shown on the add/remove
    program. So I just went through the registry and deleted everything
    associated with ringtone ripper and it fixed the problem. Thanks for
    all your help.
  18. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    > delete one
    > program
    > program
    > add/remove
    > everything
    > Thanks for
    > all your help.
    I had the exact problem, fixed after I removed Hosts file manager
    which I recently installed
    Posted using the http://www.windowsforumz.com interface, at author's request
    Articles individually checked for conformance to usenet standards
    Topic URL: http://www.windowsforumz.com/Basics-Problem-Control-Panel-Add-Remove-option-ftopict544349.html
    Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.windowsforumz.com/eform.php?p=1732418
  19. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    See also: http://aumha.net/viewtopic.php?t=14144
    Ramesh, MS-MVP
    Windows Shell/User
    Windows XP Troubleshooting
    http://www.winhelponline.com
    Windows XP Newsgroup Setup Instructions for Outlook Express:
    http://www.microsoft.com/windowsxp/expertzone/newsgroupsetup.mspx
    "walkthe" <UseLinkToEmail@WindowsForumz.com> wrote in message
    news:3_1732418_d5e873e9290956512db7c119ff938ddf@windowsforumz.com...
    > > delete one
    > > program
    > > program
    > > add/remove
    > > everything
    > > Thanks for
    > > all your help.
    > request
    > Topic URL:
Control Panel Microsoft Windows XP
