ok well im looking to make a 'gaming' rig, or as best i can get for 2000 canadian... i really cant go much past it, taxes not included..
so here is what im looking at right now, but as you can see i dont have a case picked out, but i was thinking a thermaltake kandalf or armor..
as for the graphics card, i picked out the 2900xt, though i wont be playing fps games.. i may pick up crysis though that.. probably though i will stick to rts games.. so i was thinking this may be overkill, and since i need to save money perhaps i should get a lower end card, but i was really looking forward to dx10 cards.. shader model 4.. etc
as for the Q6600 im quite adament about getting a quad core, but i need some cooling solutions for it.. i was thinking possible a sythe ninja, or something. (suggestions are welcome)
*edit(i also need a different motherboard... what stuck out in my mind was the intel 975x or the asus 680i)
(right now the cost stands at $2,406.85 so i need to cut like $600 somehow, or so because i need i case and possibly a better monitor)
***(i switched the psu to the following model but am too lazy to switch image... OCZ GameXStream 700W ATX12V 24PIN SLI Ready Active PFC ATX Power Supply 120MM Fan Black )
