I started some consulting work for a company that uses a wireless connection with 2 access points in their office (one on channel 6, the other on channel 11). They use a WPA-PSK key to secure the connection.
The problem is that with about 70% of the laptops that come preimaged from the parent company the following problem happens.
You try to connect to the wireless, enter the password, the authentication passes, an IP address is assigned, it appears connected, about 5 seconds later the connection is dropped, the computer tries to reconnect, it reconnects, then it drops and stops connecting.
I have tried the following things:
Disable all firewalls/antivirus
Reset the TCP/IP stack (using netsh int ip reset c:\resetlog.txt
Reinstalled the drivers of the card
Tried different software besides the Windows Wireless Zero Configuration (like the software for that driver)
Winsock repair
The other two things I tried with some success is:
Connecting to another wireless connection - worked but only for unsecure
Reformatted Computer (or Repaired Windows installation) - worked for 4 of the 5 computers I tried.
Now the other 30% have a similar yet annoying issue. Everytime I connect to the wireless network I get a limited, no connectivity message. I tried the same kind of things I did above but nothing worked. I'm not sure what the problem is, with one computer i actually replaced the wireless card (only to get the issue that i was getting at the top). Reformatting worked once out of 3 times on this issue.
If anyone has any ideas please let me know (especially if there is a way to fix this with out reformatting).
Here are the kinds of computers that i've been working with if its important:
Lenovo R61e
Lenovo R61i
Lenovo 3000 C200
Your problem may very well be WPA-PSK or either of the NICs.
1. Back down your wireless encryption to WEP. Try the computers out for a day. I know the WEP can be cracked in minutes, but security can be layered. Use up the length of the WEP passphrase with all the allowed characters. Use MAC filtering. Disable broadcasting. Schedule router to off during after hours. Turn on Windows firewall on the computers & block everything but the router IP. (I'm sure Vista can do that, but not sure about XP). And more... I think you know the drill.
2. Either replace the NICs or bring your own as a test.
