Power consumption BEFW11S4
Forum General Networking : General Gateways, Routers and Firewalls - Power consumption BEFW11S4
Hi, I got a Linksys BEFW11S4 wireless router, and need to know its power consumption (in watts). I contacted Linksys support, they told me it was 10 watts. Now, I know that I already got an answer for my question, but I don't know if the answer is correct.
The AC adapter on the device has 2 readings, and I don't know which is the one to go by.
Input: 110-120V, 0.5A
Output: 5V, 2.0A
Now, watts=volts*amps, but why are Linksys tech support reading the "Output" line as power consumption (which gives 5*2=10 watts)? Isn't it the "Input" that determines the power consumption? In this case, that'd be ~50watts.
Sponsored Links
you sure you read the input specs correctly? Normally it's given in 120VAC, XW not XA
<pre> \|/
jlanka (. .)
___________oOOo_(_(_)_)_oOOo___________
</pre><p>
Reply to jlanka
- 0 +
Sorry, forgot to mention that input voltage is AC, output is DC.
Reply to Dax
- 0 +
Linksys support are correct the power consumption is 10 watt
the input current is the maximum current that the adapter can support.
Reply to carecu
Tom's Hardware > Forum > General Networking > General Gateways, Routers and Firewalls > Power consumption BEFW11S4
There are 1368 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
