Hi all, I've been trying to install a new HSF (BigTyp) to my old but faithful PC because It was to hot when OCing its presscott CPU (more than 70C!).
After putting everything back, the computer would just keep beeping (continuous short beeps, 2 bp/s), and the Power LED blinks at the same time, wow!
The motherboard is an old GA-8KNXP rev 1.0, and has a label above its BIOS showing its a Phoenix one.
Before even asking what do you think its the problem, I tried to guess the problem, I hope I'm missing something:
Tried mobo w/o anything = no beep
Tried with my 3.4Ghz P4 478 Presscot CPU, continuous short beeps
Plugged in some memory, same
Plugged in my Radeon 9600 Pro, same (and no onscreen image)
Tried with my 2.4Ghz P4 478 Nortwhood CPU, the same
Also, when I plug the CPU in, it starts to get warm, not hot so it is getting power I gues...
Manual says: AWARD BIOS Beep Codes [...] Continuouss short beeps: Power error
I'm lost, I'll try another PSU tomorrow, but I don't think it has gone bad because I was trying to put a new HSF on the CPU, not touching the PSU...
Do you have any ideas of what can it be?
As I believe that the motherboard has told it's enough I face an important question, what should I do with everything else? It was my main rig... And I was going to plug an expensive X1950XT AGP to it...
Here I show a list of its components and I ask: Would you buy a motherboard compatible with them? If yes, witch one? (e.g DualVSTA from Asrock, or a better one...) if no, what would you do?
CPUs: P4 478 Presscott 3.4Ghz
P4 478 Northwood 2.4C Ghz
Mem: Kingston ValueRam 3-3-3 400Mhz
2 sticks of 512 MB each
4 sticks of 256 MB each
an ATi Radeon 9600Pro 128 MB
an ATi Radeon X1950XT'X' 256MB Brand new
I have a brand new BygTyp, also
Dead Gigabyte GA-8KNXP MoBo (Why do I list it?)
3 SATA HDDs including a 36GB raptor
1 PATA HDD and some PATA ODDs
a 480W Thermaltake PSU 18A +12V
Please, give an answer ASAP, because I'm on my 3 year old laptop with integrated graphics and It's really painful !
