Archived from groups: microsoft.public.windowsxp.basics (More info?)
David Candy Wrote:
> Where did it stall?
> --=20
> http://webdiary.smh.com.au/archive [...] 01075.html > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
> "ianowa" ianowa.1qf8do@pcbanter.net wrote in message =
> news:ianowa.1qf8do@pcbanter.net...-
> =20
> hmmm, interesting. I tried the disk cleanup but it took so long to =-
> load-
> the initial part where you select which files to clean, after two =-
> hours-
> I cancelled it.
> =20
> Bert Kinney Wrote:=20-
> Hi,
> =20
> Open My Computer - Right click on the C:\ drive and select =--
> Properties.--
> Click on Disk Cleanup. Put a check next to "Temporary Internet =--
> Files"--
> and "Temporary files" then click OK. Reboot and retry the install.
> =20
> Regards,
> Bert Kinney MS-MVP Shell/User
> http://dts-l.org/ > =20
> ianowa wrote:-
> Recently I've been trying to install some programs, and
> the installsheild wizard has appeared but before it
> finishes I get the error
> =20
> "An installation support file
> =20
> 'C:\DOCUME~1\user\LOCALS~1/Temp\{2b7bdadb-ec8c-4c54-b5dd-ce45a016d3a7}\_I=
> sres.dll'--
> could not be installed. The system cannont find the file
> specified"
> =20
> I've got this for a few files I've tried to install. Any
> help would be really appreciated. thanks.--
> =20
> =20
> --=20
> ianowa-
The initial part where it says disc cleanup is calculating how muhc
pace you will be able to free. It stops 3 bars in. Below it says
"Scanning: Compress old files"
It happens. Good news is it will fix itself in a year or so. There's no known cause and it stalls at random parts of the drive.
You can remove this feature (which is not a good idea to use it anyway unless you have a reason to compress).
Type Regedit in Start Run and go to
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\VolumeCaches\Compress old files
and delete the key. To restore type in Start Run
regsvr32 dataclen (but wait 6 months and then try every 6 months till it works)
http://webdiary.smh.com.au/archive [...] 01075.html =================================================
"ianowa" <ianowa.1qh31q@pcbanter.net> wrote in message news:ianowa.1qh31q@pcbanter.net...
> David Candy Wrote:
> > Where did it stall?
> > --=20
> > http://webdiary.smh.com.au/archive [...] 01075.html > > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
> > =20
> > load-
> > hours-
> > I cancelled it.
> > =20
> > Hi,
> > =20
> > Properties.--
> > Files"--
> > =20
> > Regards,
> > http://dts-l.org/ > > =20
> > ianowa wrote:-
> > =20
> > =20
> > sres.dll'--
> > specified"
> > =20
> > =20
> > =20
> > --=20
> > ianowa-
> ianowa
