Linksys wrt54g ethernet problem
Forum General Networking : General Gateways, Routers and Firewalls - Linksys wrt54g ethernet problem
I've had this modem router for about a year and had no problems until a couple of days ago. Connections via the ethernet ports have suddenly stopped working. Sometimes when the router is first turned on it works OK, but then the connections fail: the PC says that a network cable is unplugged (it isn't) and the router can't be pinged. Wireless connections are unaffected.
It may be a co-incidence but there was a lightening storm overhead on the evening the problem started.
Any suggestions for investigating what's gone wrong? I'd try a factory reset, but if that didn't work I'd have lost the wireless connection too.
Sponsored Links
Linksys have decided this unit is broken and they're going to replace it. Query closed.
Reply to Zetland
Tom's Hardware > Forum > General Networking > General Gateways, Routers and Firewalls > Linksys wrt54g ethernet problem
There are 477 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
