hi, every time i insert a DVD into my computer, i try and double click on the drive, but an error comes up saying
"D:\
This file does not have a program associated with it for performing these actions. Create an association in the Folder Options control panel."
what do i do?
Message edited by charlie45 on 10-03-2009 at 01:48:00 PM
Sponsored Links
Well make sure you have DVD playback software installed, could be one reason.
------------------------------ Badges? We don't need no stinkin' badges!
Reply to 4ryan6
and what program(s) like windows media player, vlc, powerDVD?
Reply to charlie45
Yes, those all play DVDs.
Reply to SevenVirtues
Yes, I would suggest DivX and VLC. Even Media Player 11 works. Make sure you update your OS to the latest service pack. I.e - XP SP3.
------------------------------ CPU: Pentium 4 641 - 3.2Ghz - Hyper Threading - 2MB Cache - 800Mhz FSB - 65nm
RAM: 2GB DDR2 Dell 800Mhz
GPU: 8600GTS 256MB GDDR3
HDD: 160GB Maxtor Sata II 7,200RPM
Reply to godbrother
As a matter of fact, when you insert it, "right click" on the D drive icon, and select "Open With" and then select your playback software from the list given.
Also, select on the bottom of that window "always open with this program"
Hope this helps.
Reply to godbrother
Hope this helps.
it opens when i AutoPlay, and it pops up, but i still cant double click on it, it keeps saying the error.. i mean its no big deal, but i wanna double click, right clicking to make a program play it is disgusting
Reply to charlie45
^^ Aww, that looks like it could be a OS bug. That used to happen to me alot on Windows XP Home. Like, 1 or 2 years down of useage, would start with these annoying bugs and glitches. Useally a fresh install will fix it, along with any other problem you may have.
But there are also ways around it. As I said, it looks like your OS is coming to the end of its life span, an needs a reinstall.
Reply to godbrother
Alright, thanks you all for the help, especially godbrother.
I should reformat soon, it's been slacking and crashing awhile now anyways
Reply to charlie45
No problem, glad I could help. :)
Reply to godbrother
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > DVD double click
There are 519 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
