I purchase a new mobo while my other one is getting fixed (warranty) since i installed the new mobo i've got jagged edges (stairsteps like lines) problem, i downloaded all the latest drivers from nvidia website and tryed differant resolutions played with settings still cant fix the jagged edges this might be a dumb question but the mobo i had was a nforce 590 the new one is a nforce4 could this be the reason maybe nforce4 has less performance ?
If anyone could help that would be much appreciated.
What resolution display? Uninstall video driver and use ccleaner to remove remains, then reinstall latest driver. Check Device Manager. Have you loaded Nforce4 drtvers? May need Repair Install due to different motherboard.
Google 'ccleaner download' If you have your desktop at 1024x768 that is NOT native resolution, and will give 'Jaggies' If you go to Display Properties - Appearance tab, Effects button. Second feature down gives 2 options to smooth edges of screen fonts.
Hi
I changed my native resolution to 1280x1024 went the smooth edges option in display properties click on cleartype option i used ccleaner and updated drivers again and i still have 'jaggies edges' lol
I'm thinking there could be a problem with my card maybe ?
