Norton nopdb.exe removal help
Archived from groups: microsoft.public.windowsxp.basics (More info?)
Hi all,
I not so recently installed norton antivirus (don'r remeber the
version) on my computer, hated it then un-installed it. For some
reason nopdb.exe is still running as a background process eating up
23Kb +- of my precious RAM. I have searched my computer for the
executable, searched the registry for it, ran msconfig to see if it is
running on startup (it is not), and I have googled "remove nopdb.exe"
among other online searches.
I have registry cleaner, spyware, and anti-virus software on my
computer and run them on a regular basis. If it makes any difference
whatsoever, the computer is dual boot XP SP1 / Mandrake 10.1. How can
I get rid of this annoying process?
Thanks, Blake
11 answers Last reply
More about norton nopdb removal help
  1. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    On 12 Jun 2005 15:47:58 -0700, Cajman wrote:
    > Hi all,
    > Thanks, Blake
    Apparently it's the executable in charge of managing scheduled runs of
    Norton's Speed Disk:
    http://www.liutilities.com/products/wintaskspro/processlibrary/nopdb/
    23kb is not really that much memory. Why do you think this is a problem?
    Sharon F
    MS-MVP ~ Windows Shell/User
  2. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    > Hi all,
    > Thanks, Blake
    Sorry did not catch the first time that you have uninstalled Norton's
    antivirus. Did you uninstall the utilities too? If yes, check in Scheduled
    Task to see if Disk Doctor still has a job here. Delete it, if found.
    Sharon F
  3. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    "Cajman" <wastedyouth821@yahoo.com> wrote in message
    news:1118616478.775213.320240@g43g2000cwa.googlegroups.com...
    > Hi all,
    > Thanks, Blake
  4. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    > Hi all,
    > Thanks, Blake
  5. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    > Hi all,
    > Thanks, Blake
  6. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    > Hi all,
    > Thanks, Blake
  7. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    Hello Blake.
    Nopdb.exe is part of Norton Systemworks.
    If there are no traces left of the installation directories, then you
    may have to use a utility called 'symclean' which you can get from the
    Symantec website. According to Symantec this utility doesn't work with
    versions 2004 & 2005, although it may have been updated. The information
    page at the Symantec site was dated Oct 2003!
    If you can not find where nopdb.exe is located on your hard drive then
    try this. Open the 'services' window, find the entry for 'Speed Disk'
    and set it to disabled.
    Finally. There are some viruses that name themselves with process names.
    Update your virus definitions and do a thorough scan.
    news:wastedyouth821@yahoo.com:
    > Hi all,
    > I not so recently installed Norton antivirus (don't remeber the
    > Thanks, Blake
  8. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    Yeah, I have been to that site, lots of good information.
    Well, on my system it is. I have 256 MB RAM and do audio/video/photo
    editing. All which you know are resource intensive. I don't have the
    money to upgrade (Differential Equations text book or RAM, tough choice
    huh?)
    I'll take everyones advice. By the way, what happened with the post?
    Why so many duplicates? I've never seen that before!
    > Sharon F
  9. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    > huh?)
    With limited resources, you're making the right decision (buying the text
    book and disabling Speed Disk). :)
    Sharon F
  10. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    I have ran a thorough scan of my anti-virus on my computer today while
    I was at school (up to date virus db), no viruses (sp?), downloaded and
    ran "symclean" several times (nothing found), Disk Doctor is not in the
    scheduled task, and I checked my processes list "Speed Disk" is not
    there. Yet this thing keeps on goin'.
    Are their any brute force methods of tracking down a process's file
    path, should I check my boot files (win.ini, system.ini)? Thanks!
  11. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    If this was on my system, I would search the registry for "nopdb.exe."
    Export and delete the reference. Also would search for the file on the hard
    drive. If found, rename it. (You're reminding me why I switched away from
    Norton's many years ago. Thank you.)
    Sharon F
Norton Computers Windows XP
