Aspire 7535g recycle bin problems
tommy231723
Hello,
my computer keeps asking me if i wish to send things to my recycly bin, example -if i double click the internet explorer on my dsktop, i get a quick pop up message sayin '' are u sure u widh to send internet explorer to the recylce bin? then i click no, but i have to click it about 15 times to make it go away. its the same with everything i double click, and sumtimes it overwites me and just deletes my files. also mif im writing an essay, if i look up my paragraph and see that ive spelt it like ib, i go back to it delete the b to replace it, then it starts delketing my whole assay, and theres nothing i can do to stop it. ALSO when my computer starts up, it starts with boot manager, how can i bypass that?
saran008
Seems that your system is affected with some kind of malware/trojan!
If you have antivirus/ antimalware installed, do a complete system scan!
or else, Download & install ,
1. Avira Anvivir - http://www.free-av.com/en/download/index.html .
Avira has very good internet security, real time updates, great overall protection.
2. Malwarebytes - http://www.malwarebytes.org/ .
Malwarebytes is one of the best malware scanners.
Scan the system & Delete the threats found!
