Tom's Hardware > Forum > Wireless Networking > Setup, Configuration & Security > Can't connect Laptop, WEP problems, clueless
Forum Wireless Networking : Setup, Configuration & Security - Can't connect Laptop, WEP problems, clueless
Basically I'm trying to set up a Wireless Connection with a Lap-top. In the settings, it has the option for an access key. It asks for a 40 bit or 104 bit WEP key. In the router it only gives me a 128-bit WEP ENCRYPTION key. I'm kind of clueless here on getting it working without turning off the security entirely. Does anyone have any tips?
Also if anyone could tell me how to access WPA security on a XP laptop I would be grateful as well.
Sponsored Links
Best post a screen of each. If you're talking about the Windows Zero Wireless, you can enter any length of key when asked and the key will be saved auto until you change it in the router.
Bring up this window:
http://www.kcexecutivecomputing.com/images/wireless-network.gif
Double-click your SSID from router and enter the key/password. Works for every type of supported encrypted from WEP, WPA to WPA2.
http://www.swtec.co.uk/common/images/wifi/wifi_wep_key_entry.png
Reply to akhilles
There are 1145 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
