Archived from groups: comp.sys.palmtops,comp.sys.handhelds (More info?)
What's faster, IR hotsync or serial cable? I've got an old laptop I want
to synch with, but I don't wanna buy the serial hotsync cable if it's just
gonna be slower than the IR (which luckily it has).
_____________________________________________________
For email response, or CC, please mailto:see.my.sig.4.addr(at)bigfoot.com.
Yeah, it's really a real address
On Sat, 18 Sep 2004 04:53:26 -0700,
In article <ka8ok0ll16vr57t9h7ql3rkrlncvpt5p6p@4ax.com>,
For an older laptop, theoretically the same. IR has two main speeds, SIR
(slow/standard infrared, 115,200bps (14KB/s) max) and FIR (4Mbps (~400KB/s)
max). However, I know of no Palm device that supports FIR, and older laptops
are unlikely to as well.
Serial ports tend to max out at 115,200bps, too. They can physically be full
duplex (i.e. send and receive at the same time) and IR can't (reflections -
receive is turned off when sending & vice versa), but since generally in
a hotsync one side is sending a lot more data than the other, the difference
will be no more than a few percent.
USB can be quite a bit faster, of course. Someday I gotta see how fast
the network hotsync would be with my Wifi card (Handera 330).
Sincerely,
Ray Ingles (313) 227-2317
A: Because it messes up the order in which people normally read text.
Q: Why is top-posting such a bad thing?
A: Top-posting.
Q: What is the most annoying thing on Usenet?
Archived from groups: comp.sys.palmtops (More info?)
On Mon, 20 Sep 2004 03:56:47 GMT, adsNO@SPAM.jecarter.com spewed:
>Serial is usually several times faster than IR.
Ah, thanks.
Do you know the bps rates? I could swear I remember IR being something
totally pathetic like 9600! But, at that rate I think it'd take way
longer than it has been to put on multi-meg. MP3's thru IR to the card..
