Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > How to convert slave hard drive to primary hard drive
Forum Windows XP : Windows XP General Discussion - How to convert slave hard drive to primary hard drive
current HD going bad, have second HD installed and using as back but now i need to make the second HD my primary, can i do this without having to reformat in order to add booting files? help
Sponsored Links
Two things, first of all have you installed to the second HDD or cloned the original HDD to the new one?
Secondly, are your hard-drives IDE or SATA?
Reply to ukcal
The easiest way to do it would be to back up your files and do a fresh install on the backup drive.
You could use something like partition magic to make a partition, and then install windows on that partiton.
------------------------------ CM HAF 932 - 300GB Velociraptor
GIGABYTE GA-EP45T-DS3R
E8500 - Sapphire 1Gb 4850
4G DDR3 OCZ Reaper 1333
Reply to aford10
There are 1004 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
