USB mapped drive problem
Forum Windows XP : Windows XP General Discussion - USB mapped drive problem
Archived from groups: microsoft.public.windowsxp.basics,microsoft.public.windowsxp.general,microsoft.public.windowsxp.hardware (More info?)
Hey everyone,
I am running Windows XP Pro. and have a number of drives mapped. My last
drive is G:. Now I need to install another USB device. The problem is that
it wont map to drive D:. It seems to want to use G:. If I dismount the G:
drive and THEN plug in the new USB device (Hard Drive) it will take drive G:
and everything works fine. Anyone know why it wont take drive H:? Thnaks
for any input.
Clayton
Sponsored Links
> last drive is G:. Now I need to install another USB device. The
> problem is that it wont map to drive D:. It seems to want to use G:.
> If I dismount the G: drive and THEN plug in the new USB device (Hard
> Drive) it will take drive G: and everything works fine. Anyone know
> why it wont take drive H:? Thnaks for any input.
Badly written code.
At least that is my determination so far.
I have had thumb drives refuse to be anything but E.. Had to give them E
and reassign in Disk Manager to something else before they would stop doing
that. And then it seemed to be a per-user thing.
Try reassigning your G temporarily to something else.. Let the drive grab G,
use Disk manager to give it another drive letter, disconnect it, reconnect
to your normal G, plug it back in.. Did that work?
Shenan Stanley
MS-MVP
Reply to Anonymous
Thanks Shenan,
I'll give that a try and report back.
Clayton
"Shenan Stanley" <newshelper@gmail.com> wrote in message
news:u4pNMdDcFHA.1504@TK2MSFTNGP15.phx.gbl...
> Badly written code.
> doing that. And then it seemed to be a per-user thing.
> G, use Disk manager to give it another drive letter, disconnect it,
> reconnect to your normal G, plug it back in.. Did that work?
> Shenan Stanley
> MS-MVP
Reply to Anonymous
Hey Shenan,
That worked! It even worked AFTER a reboot. Thanks for your help.
Clayton
> Badly written code.
> Shenan Stanley
> MS-MVP
Reply to Anonymous
> G:. If I dismount the G: drive and THEN plug in the new USB device
> (Hard Drive) it will take drive G: and everything works fine. Anyone know
Shenan Stanley wrote:
> Badly written code.
> them E and reassign in Disk Manager to something else before they
> would stop doing that. And then it seemed to be a per-user thing.
> grab G, use Disk manager to give it another drive letter, disconnect
> it, reconnect to your normal G, plug it back in.. Did that work?
> Hey Shenan,
Glad to hear it!
Shenan Stanley
MS-MVP
Reply to Anonymous
"Clayton Sutton" <none@none.com> wrote:
>Hey everyone,
>for any input.
Seems to be a WinXP bug. In my experience, the USB drive always takes
the letter right after your last hard drive partition, regardless of
whether something else (like a network drive) already has it. I've
taken to not using that letter for network mappings, leaving it
available for USB drives.
Tim Slattery
MS MVP(DTS)
Slattery_T@bls.gov
Reply to Anonymous
For auto mapping, Local drives map from A-Z, Network drives map from
Z-A. If you map drives yourself then you have to sort it yourself.
> Hey everyone,
> for any input.
> Clayton
Reply to Anonymous
Not a bug, it's been standard NT mapping for a long time. Local go A-Z,
network goes Z-A.
>>Hey everyone,
>>for any input.
Reply to Anonymous
>> Hey Shenan,
BTW, if you will attach different USB Mass Storage device, it will assign
G to the new device. Long-term solution would be to permanently change
the letter(s) of your CD/DVDs (which are somewhere between D and G
I assume) to P,Q,R,S and so on, for example.
Roman
Reply to Anonymous
>network goes Z-A.
It's not a bug if a newly arrived device takes a letter that's already
in use? Sure looks like a bug to me!
Tim Slattery
MS MVP(DTS)
Slattery_T@bls.gov
Reply to Anonymous
Archived from groups: microsoft.public.windowsxp.general (More info?)
> network goes Z-A.
It's only a "bug" if you use some other and older networking standard,
such as Novell, which has always mapped F-Z, but then Windows networking
and Novell networking have always been at odds in some way or other.
Steve
>>> Hey everyone,
>>> know why it wont take drive H:? Thnaks for any input.
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > USB mapped drive problem
There are 766 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
