Hi All,
I am trying to build my Desktop. This is first time for me. I am not a gamer. I am not planning to overclock. My primary use is for software development.
I bought ASUS P5k-E WI-AP, C2D 6600, OCZ 6400 4GB RAM and 500 GB Maxtor and Vista Ultimate. I bought some case from frys' which I don't even remember. It has 380 watts power so I belileve that would be enough. I use lot's of virutal machines so I am planning to install vista 64 on it with 8gb of RAM eventually. My questions are
1) What graphics card I should use? (Aero compatible is enough. Ofcouse 64 bit vista support. Guys I forgot to tell you. I am on really tight budget. I don't think I can spend more than a 100 on graphics card. )
2) Do I need to use any special cooling hardware?
(I would like my system to be silent. )
3) I heard that there are some graphics cards with native/passive cooling? What does it mean?
4) I saw some EVGA GEforce 7100 at frys' for $40. How do you rate it?
5) ONce the system is installed, how do I benchmark it? I will I know that the system I built is giving respectable performance?
Your help is greatly appreciated.
