Hi there, am new to this forum and only know a little about the overclocking of the new AMD Athlon 64 X2 Processors...My specs are below, I bought this pc so that i could get a decent overclock..
- 3800 X2 @ 2.4GHZ (240*10) 1.25V
- Asus M2N-VM DH Motherboard
- 2GB DDR2 800MHZ @ 880MHZ
- POV 8800GTS 320MB @ 660/850
- 3x DVD DRIVES
- 300GB HDD AND 500GB HDD
- 400W PSU
My problem is that when i change the voltage in the bios..it boots but when i switch off and switch it back on the bios does not boot...i have to restart it then it boots with an error..i go into the bios and change the voltages back to normal...then i have to change the voltages back up so that it boots..its a bit complicated but it works...why does this happen :? ?
One other thing was i set my DDR2800 down to DDR2400,HTT Multi down to 4x (tried 3x aswel) and raised the FSB to 260..it boots fine..but when loading windows i get a blue screen...
My motherboard gives me the following options for the Vcore - AUTO/1.2/1.3
but which ever setting i choose I always get the 1.2V and it does not increase...
Does anyone know what could be causing this problem?
Thank you hope to hear from someone soon
- 3x DVD DRIVES
- 400W PSU
