speed fan showing aux at 127 celsius!!!!!!!!!!!!!!!!!!
Disable AUX in speedfan. Mine fluctuated from -35C to 125C.
But I would look at your CPU temps. It cannot be higher than your core temps. It should be 10-15C lower. Try using CoreTemp to measure the cores.
Also, on my P5B-E I had to enable PECI to get a correct TCase (cpu) temp
If those are real you must have some good cooling for 3300.
bh
Ask the community
