Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Gainward 8800GTS problems
Forum Graphic & Displays : Graphics Cards - Gainward 8800GTS problems
Hi there. I've got some problems with my card and thought I'll post here and see if anyone could maybe help me :) The problem I'm having is, when playing games my computer sometimes start rebooting and giving me bluescreens. Can't really tell what message I get since it disappears within a sec. I've tried installing new drivers etc but the problem stays. Kinda nooby when it comes to stuff like this so I'm stuck right now :(
I hope someone has some solutions :) Anywayz, this is what I'm on:
Asus P5N32-E
Intel Core 2 Duo E6300
OCZ High Performance 2GB
Chieftec CFT-620A-12S 620W
Gainward BLISS GeForce 8800GTS 640MB
Thanks / sone
Sponsored Links
you forgot to mentions that removing your display driver to install modified ones like NGO causes you to loose your mobo drivers?
Reply to blade85
- 0 +
Quote :
Ah yeah, that's right :P Thanks Blade.
Reply to sone
- 0 +
well id still suggest you try the other drivers even if it means reinstalling ur mobo stuff :P
Reply to blade85
To get the BSOD or error message to show you need to disable automatic reboots @ Control panel->System->Advanced and on that page click settings for reboot & repair (roughly translated as I'm not on english XP) then untick automatic reboot. This way you can see what error it gives and post it here or Google for solutions.
GL.
Reply to morerevs
- 0 +
are you overclocking anything, cpu maybe?? if yes then maybe its not stable enough to run games, but stable enough to do everything eles
Reply to accu
There are 1077 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 bew1075k won the Uniformed badge
  • 01:00 Parasitic won the Uniformed badge
  • 01:00 X3no won the Uniformed badge
  • 01:00 Siq won the Uniformed badge
  • 01:00 wayspooled won the Uniformed badge
  • 01:00 chris62 won the Freshman badge
  • 01:00 Tattysnuc won the Freshman badge
  • 01:00 gamerk316 won the Freshman badge
  • 05:23 jsc won the Overclocking badge
  • 01:00 rolli59 won the Spy badge
