My new company I work for has a very weird VPN problem. Since I work at home I need to connect to their servers, but they said you can not connect if your routers start with 192.168.x.x and you would need to change it to 172.16.x.x
The major problem is that my whole house is networked in 192.168.x.x and I tried changing things to 172.16.x.x and it REALLY messed up my home network, lots of weird stuff happening. As I spend 3 hours with our IT dept changing things back to original settings. Only way I am overcoming this problem is using dial-up
Any help or advice is appreciated! IT department said they will be changing it to be compatible with 192.168.x.x in the NEAR future since a majority of us who connect at home has theses settings. Thanks
