Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Basic advice for cleaning registry on XP?
Forum Windows XP : Windows XP General Discussion - Basic advice for cleaning registry on XP?
So my second computer is about 5 years old, and it's starting to be slowed noticeably by "Windows rot." A lot of it probably has to do with leftover garbage in the registry from the dozens and dozens of programs that have been installed and uninstalled over the life of that machine, but I am really not well versed on how to clean up the registry.
I know re-installing Windows would probably solve most of those problems easily, but I don't want to do that because I've got so much stuff I don't want to lose. I also don't want to just go in there and start messing with the registry, or download a program that I'm less than sure about to do it for me, because I know that can really mess things up if you do it wrong. Basically, I'm just looking for any recommendations from someone who has successfully done this before.
Message edited by capt_taco on 10-25-2009 at 02:22:47 AM
Sponsored Links
I use TweakNow RegCleaner, free to use. it cleans up the registry and there is an option to defragment the registry also, although this requires you to restart the computer immediately after it completes. After the computer restarts, the application then tells you to what extent the registry has been defragmented.
Reply to daviduk109
- 0 +
I've never used that ^ program. I personally use ccleaner.
------------------------------ CM HAF 932 - 300GB Velociraptor
GIGABYTE GA-EP45T-DS3R
E8500 - Sapphire 1Gb 4850
4G DDR3 OCZ Reaper 1333
Reply to aford10
I checked it out and TweakNow looked pretty good, so I tried it. It definitely did some good -- found 900+ problems, including things like leftover entries from Maxthon browser and AOL dial-up from five years ago. Most importantly, it didn't do any harm, so I'll give it my endorsement.
On the downside, the computer boots up almost exactly as slowly as before, so it probably didn't get everything. *sigh* I will probably try ccleaner in the morning.
Reply to capt_taco
have you tried reducing to an absolute minimum the number of applications that start up when windows start up? Slow start ups can be the result of too much crap running in the background that start up as windows starts up. My networked pc at work has so much crap running in the background that it takes nearly 10 minutes to fully boot up in the mornings.
You can see and reduce the number of applications that start up when windows starts up by clicking on 'start' then 'run' then typing in 'msconfig'. However this is fairly common knowledge now so I would be surprised if you did not already know this.
Reply to daviduk109
- 0 +
I would also advise checking the startup folder in the start/all programs menu. You can remove programs from there to stop them from starting with windows.
Reply to aford10
There are 1120 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
