Basic info on Vegas Pro 8.0 network rendering
If anybody is familiar with network rendering with Vegas Pro v8.0
could you give some basic info to get started?
questions
1) would I be better off using 8 Pentium 4 2.8 HT towers in a render farm
2) or is it better to use a Dual Xeon P4 3.2 HT to send the render job to?
This is for amateur work at home (daughter is wannabe popstar plus I like playing with my home movies)
The render jobs arent time critical
I just dont want them hogging my tower
I think I am better off using the Dual Xeon as a headless unit under the desk
if somebody could give a basic tutorial on setting that up
I would appreciate
does the rendering tower need Vegas installed also?
could it be headless unit?
I have a kvm switch and two displays so it isnt a big deal if it cant be headless
thanks in advance
Nevermind
I spent until 7am studying tutorial
and waa able to setup a renderer and did
two succesful render jobs
Pretty awesome
Now I have to figure a way to make the render machine headless
under my desk
Anybody who posts anything on this thread that is interesting
or funny will get a best answer if it matters to you :)
