Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Installing .net 3.5 on xp x64 problem
trying to install .net 3.5 sp1 on xp corporate x64 and i cant install it nor can i uninstall my previous .net version says error 1719 windows installer could not be accessed when i try to uninstall and when i try to install 3.5 it says
[08/10/09,12:58:13] MSXML 6.0 Parser x64: [2] Error: Installation failed for component MSXML 6.0 Parser x64. MSI returned error code 1603
[08/10/09,13:21:31] MSXML 6.0 Parser x64: [2] Error: Installation failed for component MSXML 6.0 Parser x64. MSI returned error code 1603
[08/10/09,13:23:51] MSXML 6.0 Parser x64: [2] Error: Installation failed for component MSXML 6.0 Parser x64. MSI returned error code 1603
[08/10/09,13:25:46] MSXML 6.0 Parser x64: [2] Error: Installation failed for component MSXML 6.0 Parser x64. MSI returned error code 1603
[08/10/09,13:28:36] MSXML 6.0 Parser x64: [2] Error: Installation failed for component MSXML 6.0 Parser x64. MSI returned error code 1603
[08/20/09,20:32:29] MSXML 6.0 Parser x64: [2] Error: Installation failed for component MSXML 6.0 Parser x64. MSI returned error code 1603
[08/21/09,23:24:35] MSXML 6.0 Parser x64: [2] Error: Installation failed for component MSXML 6.0 Parser x64. MSI returned error code 1603
[10/27/09,15:11:04] MSXML 6.0 Parser x64: [2] Error: Installation failed for component MSXML 6.0 Parser x64. MSI returned error code 1603
[10/27/09,15:11:06] WapUI: [2] DepCheck indicates MSXML 6.0 Parser x64 is not installed.
[10/27/09,15:12:57] MSXML 6.0 Parser x64: [2] Error: Installation failed for component MSXML 6.0 Parser x64. MSI returned error code 1603
[10/27/09,15:13:00] WapUI: [2] DepCheck indicates MSXML 6.0 Parser x64 is not installed.
[10/27/09,15:14:05] MSXML 6.0 Parser x64: [2] Error: Installation failed for component MSXML 6.0 Parser x64. MSI returned error code 1603
[10/27/09,15:14:07] WapUI: [2] DepCheck indicates MSXML 6.0 Parser x64 is not installed.
[10/27/09,17:11:00] MSXML 6.0 Parser x64: [2] Error: Installation failed for component MSXML 6.0 Parser x64. MSI returned error code 1603
[10/27/09,17:11:03] WapUI: [2] DepCheck indicates MSXML 6.0 Parser x64 is not installed.
[10/27/09,17:36:41] MSXML 6.0 Parser x64: [2] Error: Installation failed for component MSXML 6.0 Parser x64. MSI returned error code 1603
[10/27/09,17:36:43] WapUI: [2] DepCheck indicates MSXML 6.0 Parser x64 is not installed.
[10/27/09,17:42:44] MSXML 6.0 Parser x64: [2] Error: Installation failed for component MSXML 6.0 Parser x64. MSI returned error code 1603
[10/27/09,17:42:46] WapUI: [2] DepCheck indicates MSXML 6.0 Parser x64 is not installed.
[10/27/09,17:54:34] MSXML 6.0 Parser x64: [2] Error: Installation failed for component MSXML 6.0 Parser x64. MSI returned error code 1603
[10/27/09,17:54:36] WapUI: [2] DepCheck indicates MSXML 6.0 Parser x64 is not installed.
[10/27/09,17:57:24] MSXML 6.0 Parser x64: [2] Error: Installation failed for component MSXML 6.0 Parser x64. MSI returned error code 1603
[10/27/09,17:57:27] WapUI: [2] DepCheck indicates MSXML 6.0 Parser x64 is not installed.
[10/27/09,18:02:17] MSXML 6.0 Parser x64: [2] Error: Installation failed for component MSXML 6.0 Parser x64. MSI returned error code 1603
[10/27/09,18:02:20] WapUI: [2] DepCheck indicates MSXML 6.0 Parser x64 is not installed.
[10/27/09,18:09:18] MSXML 6.0 Parser x64: [2] Error: Installation failed for component MSXML 6.0 Parser x64. MSI returned error code 1603
[10/27/09,18:09:20] WapUI: [2] DepCheck indicates MSXML 6.0 Parser x64 is not installed.
[10/27/09,18:16:43] MSXML 6.0 Parser x64: [2] Error: Installation failed for component MSXML 6.0 Parser x64. MSI returned error code 1603
[10/27/09,18:16:46] WapUI: [2] DepCheck indicates MSXML 6.0 Parser x64 is not installed.
[10/27/09,18:28:05] Windows Installer Patch Registration Fix for .NET Framework 3.5 (x64): [2] dlmgr: dlmgr::CDownloadJobURLMonImpl::Failed: URLMonError: Download failure (0x800c0005)
[10/27/09,18:28:05] Windows Installer Patch Registration Fix for .NET Framework 3.5 (x64): [2] dlmgr: dlmgr::JobBase::Retry: all retries failed
[10/27/09,18:28:06] Windows Installer Patch Registration Fix for .NET Framework 3.5 (x64): [2] Failed to fetch setup file in CBaseComponent::PreInstall()
[10/27/09,18:28:06] setup.exe: [2] ISetupComponent::Pre/Post/Install() failed in ISetupManager::InternalInstallManager() with HRESULT -2147467260.
[10/27/09,18:28:06] setup.exe: [2] CSetupManager::RunInstallPhase() - Call to Pre/Install/Post for InstallComponents failed
[10/27/09,18:28:06] setup.exe: [2] CSetupManager::RunInstallPhaseAndCheckResults() - RunInstallPhase() returned a NULL piActionResults
[10/27/09,18:28:06] setup.exe: [2] CSetupManager::RunInstallFromList() - RunInstallPhaseAndCheckResults failed [2]
[10/27/09,18:28:06] setup.exe: [2] ISetupManager::RunInstallLists(IP_PREINSTALL failed in ISetupManager::RunInstallFromThread()
[10/27/09,18:28:06] setup.exe: [2] ISetupManager::RunInstallFromThread() failed in ISetupManager::RunInstall()
[10/27/09,18:28:06] setup.exe: [2] CSetupManager::Run() - Call to RunInstall() failed
[10/27/09,18:28:06] WapUI: [2] DepCheck indicates Windows Installer Patch Registration Fix for .NET Framework 3.5 (x64) is not installed.
[10/27/09,18:28:06] WapUI: [2] DepCheck indicates MSXML 6.0 Parser x64 was not attempted to be installed.
[10/27/09,18:28:06] WapUI: [2] DepCheck indicates WIC x64 Installer was not attempted to be installed.
[10/27/09,18:28:06] WapUI: [2] DepCheck indicates Microsoft .NET Framework 2.0a x64 was not attempted to be installed.
[10/27/09,18:28:06] WapUI: [2] DepCheck indicates XPSEPSC x64 Installer was not attempted to be installed.
[10/27/09,18:28:06] WapUI: [2] DepCheck indicates Microsoft .NET Framework 3.0 SP2 x64 was not attempted to be installed.
[10/27/09,18:28:06] WapUI: [2] DepCheck indicates Microsoft .NET Framework 3.5 (x64) 'package' was not attempted to be installed.
[10/27/09,19:00:06] MSXML 6.0 Parser x64: [2] Error: Installation failed for component MSXML 6.0 Parser x64. MSI returned error code 1603
[10/27/09,19:00:10] WapUI: [2] DepCheck indicates MSXML 6.0 Parser x64 is not installed.
so to try and combat i tried to install windows installer to uninstall the previous version and it says that it was installed correctly, did not fix the problem so i tried to install MSXML 6.0 and it says windows installer could not be accessed and i also checked in services to make sure that windows installer was running im just at a loss for ideas...any suggestions or any more info u need let me know
Sponsored Links
There are 1178 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
