Inventor/ port80 problem
Forum Windows XP : Windows XP General Discussion - Inventor/ port80 problem
Hi there, Trying to install Inventor 2009, all fine until diagnostic tests and then I get error saying port80 being used by another prog. Using windowsxp on an IBMthinkpad laptop I'm using agv anti-virus. Tried ending the task. I have uninstalled the whole autodesk suite and iTunes and still no joy. Tried loads of forums, nothing doing Help I'm losing the plot here!!! Appreciate any help. Thanks
Sponsored Links
Ha, thats an odd one, Port 80 is actually the native port for an Internet Connection. I would suggest you change the port that Inventor uses.
It is possible to use a different port when browsing, by putting the domain name then a colon and the desired port number.
Try both solutions and post back if neither work.
Reply to deadjon
Tried changing port that it uses, nowt. grrrrrrr.
Seriously think it's an issue with avg anti virus or the Content center within autodesk suite.
Every time I end task it immediately kicks back in using a differrent PID number.
Ta for help.... Bin looming for laptop methinks!
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Inventor/ port80 problem
There are 1156 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
