Tom's Hardware > Forum > Wireless Networking > Setup, Configuration & Security > Linksys wireless usb adapter not connecting to my Linksys wireless Rou
Forum Wireless Networking : Setup, Configuration & Security - Linksys wireless usb adapter not connecting to my Linksys wireless Rou
I just bought a wireless adapter for my pc, and it won't connect to my wireless Linksys router downstairs. They're both compatible because it says on the box, and I've used it with my Xbox and my Wii and it worked fine. My computer is getting a strong signal and it connects but I dont have internet access. I even turned off my network security just to make sure and still no luck. Anyone have suggestions?
Sponsored Links
Check you haven't turned on Access Control (include or exclude by MAC id) in the router.
Alternatively you may have a faulty wireless adapter -- you seem to indicate that the router is okay with Xbox and Wii -- but, if poss, check the new unit with another router.
Reply to fihart
The wireless adapter does work, I connected to my neighbor's network to test it and it worked fine, though I don't like stealing their connection, I'd like to get my own working.
Reply to mrmatt91
Then as fihart said, you've probably got access control running on the router.
check the router controls for what protection you have running
Reply to Cedric Tsui
There are 1249 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
