Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Please help, restoring hard drive data
Forum Windows XP : Windows XP General Discussion - Please help, restoring hard drive data
Hello,
i will make long story short, i just formated my old hard disk with all the important data and installed windows over it.
i really don't know what to do!!!
right away after i finished to install windows i discoverd the mistake!
there is a way to restore evertying?
some details:
the old version that was installed on the HD was XP Pro and the current is XP Home editon.
the HD hat two partitions C and D, now there is only C.
i chose the Quick NTFS formmating option.
HEELLPPP i don't know what to do!!!
thanks
Amit
Sponsored Links
Use Active file recovery or on track easy recovery. Both are good, but i prefer the firts, this give me great results with a 500GB HDD, 120GB HDD and 80GB HDD.
------------------------------ If you like my answer, select me as the best answer.
"Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.". Albert Einstein.
Reply to saint19
There are 1078 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
