Tom's Hardware > Forum > Wireless Networking > Setup, Configuration & Security > Using two Wifi with one Cable modem
Forum Wireless Networking : Setup, Configuration & Security - Using two Wifi with one Cable modem
How to connect two Wifi AP to a one internet connection(SHAW). I have a cable modem on 2nd floor of my house and a Linksys WRT54GL router. Now my brother living in the basement want to use his own Linksys WiFi router with this existing internet connection. Is there any way i can use both WiFi routers on same internet connection by using switch/router after DSL modem. Your suggestion will be much appreciated. Thank you.
Sponsored Links
yo can use one router and connect it to the modem, and then from your router you cna plug to basement linksys.
Reply to charithrac
my router has something called WDS. heres what the router says
Wireless Distribution System uses wireless media to communicate with other APs, like the Ethernet does. To do this, you must set these APs in the same channel and set MAC address of other APs which you want to communicate with in the table and then enable the WDS.
i had a netgear router that had a similar option but wasn't called WDS.
Reply to pjumpleby
There are 769 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
