PLEASE READ and HELP.
im confused on what video card to get, and what will fit my computer. I have a dell with p4 3.0ghz, 512mb ram, 120gb harddrive, a 305W psu, and a FX5200 video card now. I wanted to know what would be the best video card to get for around $100-150. and i would buy a 450 watt psu.
More about : read
Graphics card Expert
Quote:
I want to know if i should get a X1950GT, or get a 7600GT ( AGP BUS.)? but i think my psu is only a dell 375W 30amp +12v. im going to make sure in a second. but please help me, i dont know what to do, and i dont know if it will bottleneck, i have a dell, p4 3.0ghz, 512mb ram, 120gb harddrive, 375w psu.
Your 375w, 30a PSU should be fine adding a 7600 series card. My best AGP cards are an x800GTO and a 6600GT. Both run 1440 x 900 on 19" widescreens. The 7600 series should work well on what you have.
okay, im thinking i might buy a 450-500 watt psu, and then buy a 7600gt 256mb on newegg for like $119. I just looked in my computer, it has a 305W, so i definetly need to upgrade that. Im really doing this for gaming, because my FX5200 isnt a real good performance card for gaming and fps. I normally play call of duty and call of duty 2, and i get like 70 fps in call of duty 1 on 1024x768 on high settings. On call of duty 2 i get like 30 fps. I wanted to get a card to make it atleast 200-250 on call of duty 1, and atleast 60-80 on call of duty 2
Why don't you buy the card and try it with what you have. The 7600 doesn't use a direct 12v power supply source, it draws power from the MB AGP slot. You better check around, some people have run into problems replacing the PSU's on Dell systems. I've never owned a Dell, so I'm unfamiliar.
Related ressources
Quote:
how about this 7600GT, its low priced, and has some good reviews..
That is excellent, I might buy one myself! Yeah, that card wouild be a major boost in your gaming experience for sure. And you can probably just install it in your system without changing the PSU. I would say go for it.
BTW. I installed a 7600GT PCIE for a kid months ago. He plays organized gaming competively all the time with it. For him, it was the perfect choice.
Nooooo. If you're going to buy a new PSU, get the X1950GT. It's the same price as the 7600GT, and it'll kick the living $hit out of it.
yeah the 7600GT does kick some ass, my brother has the pcie one and it just screams, sometimes he gets too much fps and looses connection lol. but anyways. Should i risk taking 7600GT and not a new psu, or should i get the psu, and get the X1950GT?
i think im just going to actually get the 7600GT, so i can save about $100 for my next rig in about 2 years. im going to overhaul it, and get all the bells and whistles later on. but i think i am going to get that 7600GT. it does make a diffrence when u play with a FX5200 128mb card. and u lag alot too when u are in smoke. so ill look forward to that.
im not sure though. people are saying go for the X1950GT, and get the like 450-500W psu, so you dont have to worry about the watts drawn. But this happened on my dads computer when i got a video card for him, he has a 300W psu and i put a card recommended 350W, and it drawn in to much power, and our internet kept loosing connection, so i might actually go for the psu and card.
Well, if you open up your case, the specs are listed on the side of your PSU. Take a look at the +12V amperage. If it supplies at least 18amps, your fine for a 7600GT, if not buy a new 450W PSU with 30amps on the +12V rail, and get the X1950GT. It would just suck to buy the 7600GT, only to find out that it doesn't work with your current PSU. Then you're stuck buying a new PSU, and not getting your money's worth out of your GPU.
Ask the community
