Yog: usb problem
Forum Windows XP : Configuration & Customize - Yog: usb problem
hi
i have a 32 gb Hisun usb flash drive
it was working fine and then i decided to install xp on it using the bartPE program.
I had it in 2 partitions(public and private)I did this with the JFutility that comes with it.
So I used the JFutility to merge it back into 1 partition. this completed sucesfully.
However it formated it as a "RAW" file format. If I try 2 open it in my computer I get the error
"the disc in drive G is not formated. Do u want 2 format it now"
if i try 2 format i get the error
"Windows was unable to complete the format"
i have tried using fat/fat32 and quick/full format.
i have tried changing the drive letter to Z aswell
I then tried formating with the program
"HP USB Disk Storage Format Tool"
I get the same error
Any ideas any1 :?:
PLZ i need help :!:
Sponsored Links
Tom's Hardware > Forum > Windows XP > Configuration & Customize > Yog: usb problem
There are 1116 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
