Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Need some help. Power supply or motherboard?
So I assembled my new PC. Everything went fairly smoothly I guess considering I'd never built one before.
Anyway... I hooked everything up... double checked all the connections.
Plugged in the power supply... hit the switch on the power supply... the light on the motherboard never went on. Obviously the system wouldn't even turn on. Here are the parts I purchased from Directcanada.com
OCZ GameXStream 700W power supply
Asus P5K Deluxe/WiFi-AP motherboard
Antec P182 case
Intel C2Q Q6600
2x Team Xtreem Dark Series PC2-6400 2GB 2X1GB DDR2-800 CL 4-4-4-12
BFG GeForce 8800GTX OC 600MHZ 768MB 1.8GHZ
Any insight would be greatly appreciated.
Sponsored Links
Double check the front panel case connections and make sure they're hooked up properly to the right M/B header connections according to your M/B manual, that can sometimes be a little confusing so double check it.
Reply to 4ryan6
Would that actually explain why the motherboard LED doesn't even light up? It's like the MB isn't getting power at all. I wouldn't think the front panel connectors would have anything to do with that, but the members on these forumz certainly know more than I do.
Tonight I will try a "bare-bones" build and see if that works.
Reply to vertigo_2000
- 0 +
You DID use standoffs to support motherboard :?:
Mike.
Reply to mike99
Quote :
Mike.
Use what?
j/k of course I did. 8)
Sounds like either PSU or MOBO is totally DOA. As suggested, check PSU for sure. But you can do a quick and dirty check of the PSU without a PSU tester - take the power supply out of the case and jump one green with any of the black wires and turn on the power supply. It should start up and spin. If this works I'd say RMA that MOBO.
Reply to notherdude
- 0 +
Whats your status?
Still dead or up and running?
Reply to 4ryan6
I hooked up another power supply to the mobo and all the lights on the mobo came on.
Safe to say the power supply was DOA.
I am now in the process of RMA'ing it back to directcanada.com.
Here's the process:
I pay to send it back to them.
They credit/debit (whatever it is) my credit card.
Then I have to reorder another one which requires another credit card transaction and they send it to me with free shipping. So in the end... I should get a working power supply, but I'm out a little more money 'cause I had to ship their defective part back to them. I have a talk to them about that part of it. :D
I wonder how this is going to affect the MIR the power supply had when I originally ordered it.
- 0 +
I'm sure you knew this but there is also a power switch on the back of the PSU. You turned that on as well, right?
Just mentioning, once I had a panic attack when after reassembling there was no juice. Forgot to flip the switch.
Reply to haywood
lol... panic can set in pretty quickly huh?
But yeah... the switch was tried in both positions just to be certain.
Thanks for caring enough to post though.
- 0 +
Quote :
Make sure you keep your records on the RMA, shipping, time lost Etc. so you can prove it if you have to, hopefully once you get the P/S back you'll have no other problems. :wink:
Reply to 4ryan6
- 0 +
Well at least you remembered to plug the power cord into the wall socket. :lol:
Reply to 4ryan6
<slaps forehead>
The second P/S was plugged in, maybe the OCZ one wasn't!!!
:lol:
That would be a monumental blunder if it were true. To late now anyway... the P/S is at the post office ready to be sent back.
Brad at directcanada.com has been extremely helpful and apparently is overnighting a new one with no shipping charges.
There are 1254 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
