I'm trying to create a very flat case, so instead of putting my ATI 1800 16x PCIe card directly into the mobo, I want to connect it by a cable and lay it flat next to the mobo. The problem is I have searched and searched and cannot find such a cable to be in existence. It seems like a fairly easy cable to make, just the male/female ends of the PCIe connections. Anybody know if/where I can get one of these? Thanks!
After I read Kbits post I actually found this. This is not exactly what I had in mind (I was trying to make a small cpu fan the highest thing on the board) but it might work. Thanks for the help (and if anyone wants to solder me a cable, let me know ).
PS chunkymonster: Congratz on the thousandth post.
Yeah, I'm probably not dedicated enough to solder a new input slot. The cable thing didn't seem so outrageous as a mystical smoke changing thingembob. And I haven't hunted snipe for ages.
Basically you want a cable made up so that the card can lie completely separately next to the board?
You are talking about at least a 15cm cable length, and twisting said cable....
PCIe isn't designed for an extra 15cm trace length, let alone the reflections and interference caused by twisting the cable or laying it back on itself...
The PCIe SIG has designed connectors and cables for external mounting, but no current PCIe controllers support the different voltage levels etc these allow for in order to cope with this.
