Do I want to keep the cpu-z timing under 667, or under 334, when dealing with an AMD 3600+ x2 and a biostar tf7025 motherboard?
If I overclock the CPU to run at 250x9.5, it ups the memory speed to around 397 or so (don't have it overclocked, and didn't write it down, sorry). Its kingston-5300 memory, and ran fine at this while I tested prime-95 for 15 minutes, but didn't want to fry the memory until I got better information.
If I need to keep it under 334, then I'd want to bump the memory divider up from 6 to 7 (speed versus memory divider in cpu-z)
or can I safely reduce the multiplier even at stock speed of 1.9ghz, so that the memory is running at 633 or speed/3?
I am running the memory in both the right spots to enable the dual channel aspect.
