P182 - Will it house these parts?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - P182 - Will it house these parts?
I'm building a new system, and I've been looking for a suitable case. Not looking for anything too flashy, just functional and sleek - and the P182 looked to be a good fit.
I was wondering if it would fit a Asus Striker, or eVGA/BFG mobo(mobo tips would be good too), BFG 8800 GTX OC, and a OCZ 850W GameXStream PSU. Also, I was wondering if it would fit 2 8800 GTX's as that's my half-way upgrade plan when the PC starts slowing down or a windfall.
Sponsored Links
Quote :
I was wondering if it would fit a Asus Striker, Also, I was wondering if it would fit 2 8800 GTX's
ya, just push on stuff real hard
Reply to SasparillaMayonase
A good sledgehammer should solve it very quickly :P
Seriously now, the 8800 GTX cards will fit, but barely, which is bad for cooling and will require leaving some hard disk bays empty. I don't know about the PSU, it may be too big.
I'd consider a bigger case such as Thermaltake Armor or Silverstone TJ09.
Reply to aevm
You might run into problems with that power supply because its too long, and then you'll have to remove the lower fan to get it to fit.
The graphics cards should fit as long as you remove the upper HDD cage.
Reply to malcom
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > P182 - Will it house these parts?
There are 1333 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
