Question, got a wireless router, laptop, and desktop pc. Desktop is connected to internet via ethernet cable, no wireless card installed. Laptop is a macbook and works fine on wireless to get to internet. However they cannot see each other on my network. As in the laptop cannot ping the pc successfully, but the desktop can ping the laptop. So it's like the laptop just can't see the desktop. Anyway to fix this, or do I need to get a wireless card for the desktop? Btw, wouldn't be too concerned if my network went all wireless as I'm running WPA security, with 64 character length HEX password, and can enable MAC address filtering, as well as running software fiewall on the desktop.
Sponsored Links
It's the firewall on the desktop. You need to add your IP address range to the Trusted Zone.
Grumpy
Reply to Grumpy9117
No, b/c I also tried turning the firewall off, at least I'm fairly certain, and I don't think the windows firewall was enabled either.
Message edited by ohiou_grad_06 on 02-25-2008 at 04:36:19 AM
Reply to ohiou_grad_06
Try this. Boot your desktop into Safe Mode with Networking and try pinging your laptop.
Grumpy
Reply to Grumpy9117
wrong, the MAC book needs to turn on Windows sharing and Personal file sharing checked off in system preferences/sharing. When done sharing it will ask a name for windows sharing, give the name of the windows PC. Then share the files on the windows machine. This is al you should have to do, this is what I did and it took 5 minutes.
Reply to rattman169
Tom's Hardware > Forum > General Networking > Network General Discussions > Wired and wireless
There are 1210 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
