i have a problem with my Asus en 8800GTS 320MB... when playing for a long time with it maybe 7 -8 hours, the game start to lag (im playing warcraft III (it should be no problem)) but my computer isnt lagging i can alt+tab and my winamp still running well and can still give commands to the units without any problem, but the graphics is lagging (in some game the game just closed)..... my VGA temp is 60-65C <-- normal isnt it
but when i restart my computer... the problem gone... so ? what is the problem....
system :
am2 athlon 64 4600+
DFI infinity ultra II
1 GB corsair
320 GB sata II & 160 GB ata HD
windows XP sp2
450W simcool cassing
I've played Warcraft III before, if you play online too long it starts to lag for some reason. I think for me it was the network lagging, not the graphics. I'm not sure since I haven't played it since my old PC. (Pentium II 400mhz, 256mb RAM, ATi Rage 128) Sometimes I wonder how I played Warcraft III on that.
warcraft III was an example... it still lag even if im not playing, like if im going to my office (and i left my PC on at home), when i come home from work then play warcraft the FPS was like droping... and other game (i play fable too) just closed......
the point is my 8800GTS has a problem when turned on for about 7-8 hours, but my PC is doing fine... but when i restart my PC... the problem gone...
Go to task manager and see how much memory and cpu usage you have. Could be a memory leak
Exactly what I was thinking. He mentioned the symptoms of a memory leak.
Close all the startup programs you can by going to run, type in msconfig, click on the startup tab, and click off anything not important. If that don't work shut down all programs in taskmanager that it lets you and see if you can play longer. You can do a guess in check till you find the program with the memory leak.
[Off topic]
Note for your simcool 450W psu, it will blow your EN8800GTS 320 out. A friend of mine also used that psu and his 7300GT got burned and void the warranty of the vga. Careful....
all, thanks a lot for your replies.. gonna try that.... and post the result here soon ^_^
Quote :
wow... should i get a new PSU for the cassing ? if yes what PSU would u recommend?
i do get the same lag as well if playing too long
also when playing too long i also get an error message in game
"warning : low texture 3xmb"
game that i'm playing EQ1
my system :
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.070227-2254)
Language: Chinese (Regional Setting: Chinese)
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: 965P-S3
BIOS: Award Modular BIOS v6.00PG
Processor: Intel(R) Core(TM)2 CPU 6320 @ 1.86GHz (2 CPUs)
Memory: 2046MB RAM
Page File: 339MB used, 3599MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
copy paste from dxdiag :
[code:1:f11e467e5e]
System Information
Time of this report: 7/4/2007, 19:55:41
Machine name: PANZZ
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
Language: English (Regional Setting: English)
System Manufacturer: NVIDIA
System Model: AWRDACPI
BIOS: )Phoenix - Award WorkstationBIOS v6.00PG
Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 4600+, MMX, 3DNow (2 CPUs), ~2.4GHz
Memory: 1024MB RAM
Page File: 444MB used, 2017MB available
Display Devices
Card name: NVIDIA GeForce 8800 GTS
Chip type: GeForce 8800 GTS
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0193&SUBSYS_823C1043&REV_A2
Display Memory: 320.0 MB
Current Mode: 1280 x 1024 (32 bit) (75Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.9794 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 2/23/2007 10:25:00, 5747200 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 2/23/2007 10:25:00, 5749472 bytes
Device Identifier: {D7B71E3E-42D3-11CF-B155-36A203C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0193
SubSys ID: 0x823C1043
Revision ID: 0x00A2
Revision ID: 0x00A2
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: All tests were successful.
D3D7 Test Result: All tests were successful.
D3D8 Test Result: All tests were successful.
D3D9 Test Result: All tests were successful.[/code:1:f11e467e5e]
After 7-8 hours maybe your eyes are starting to lag...?
