Window XP beep problems
We are sharing Windows XP with VxWorks on the same processor. Windows basically runs as an idle task under vxWorks. The vxWorks side runs a task that sounds a beep on the system board speaker.
This worked fine until we changed hardware platform to a Dell Latitude E6500. Now the beep only works if we generate a beep on the Windows side due to opening a Windows Explorer window and then the
vxworks beep sounds for one minute and then stops until another Windows event triggers a beep.
Anyone know what's happening here?
2 answers Last reply
More about window beep problems
  1. That`s BIOS beep code.(If I am wrong correct me)
    1 short beeps Normal POST - system is ok
    2 short beeps POST Error - error code shown on screen
    No beep Power supply or system board problem
    Continuous beep Power supply, system board, or keyboard problem
    Repeating short beeps Power supply or system board problem
    1 long, 1 short beep System board problem
    1 long, 2 short beeps Display adapter problem (MDA, CGA)
    1 long, 3 short beeps Enhanced Graphics Adapter (EGA)
    3 long beeps 3270 keyboard card
  2. I´m having the same problem. Have you found a solution? I´d thank you very much.
Drivers Windows Explorer Processors Windows XP
