Help deciding fans?
Forum CPU & Components : Other Components - Help deciding fans?
Hey everyone. I'm trying to decide which fans would be the best option for my PC. I need good options for buying, and i want good performance fans (120mm).
It must meet the follow conditions:
120mm
Makes less than 25 dbA of noise
Must be well built
LED Light (Blue)
Some way to easy make it faster or slower when required
As long as they don't pass of $20, all fine. I need silent ones, but of course a decent CFM (I don't know, maybe at least 30?). As far I had researched, the Antec's TriCool LED looks like a good option. But, which would you recommend?
Thank for any help.
Sponsored Links
Buy a bunch of these:
http://www.jab-tech.com/YATE-LOON- [...] -3773.html
Good price, and great fan company.
Reply to enforcerfx
Here you go, a selection of 120mm, blue LED case fans. You'll have to pick through them for the Db you're looking for, but the Logisys don't look too shabby.
http://www.newegg.com/Product/Prod [...] rchInDesc=
Reply to kitchenshark
Don't buy the ones listed by kitchen. Yateloon fans are in the category with SilenX and Noctua when it comes to quiet fans, and lots of air being moved.
Reply to enforcerfx
Just keep in mind that manufacturers of fans lie shamelessly when it comes to noise ratings. Sure you get something blue and shiny but theres no way its actually as quiet as it claims. I got stung with a couple - coolink i think
Reply to TheRodent
Tom's Hardware > Forum > CPU & Components > Other Components > Help deciding fans?
There are 1188 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vishnuvamp won the Freshman badge
  • 01:00 whiz won the Freshman badge
  • 01:00 jconline won the Uniformed badge
  • 01:00 qiaoda won the Uniformed badge
  • 01:00 sykohedd won the Uniformed badge
  • 01:00 jundja won the Uniformed badge
  • 01:00 cnsftci won the Uniformed badge
  • 01:00 VistaVendetta won the Uniformed badge
  • 01:00 batuchka won the Uniformed badge
  • 01:00 Nick_C won the Uniformed badge
